TIG Welding Carbon Steel Fillet Tube at 160 amps welderskills
scroll down for settings and details
METAL TYPE = CARBON STEEL
THICKNESS = 1/4” WALL THICKNESS
TUBE TO FITTING
WELD TYPE = FILLET
JOINT TYPE = FITTING TO TUBE
POSITION = 2F
AMPERAGE = MACHINE SET TO 160 AMPS  AND MAXED
TUNGSTEN = 2% LANTHANATED, 3/32"FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
snip any oxidized tip of wire before restart
