TIG WELDING CARBON STEEL 1/4" THICK CORNER JOINT PULSE ROOT LAYWIRE TECHNIQUE
scroll down for TIG welder settings
We put together this tungsten bundle because 3/32" is the most versatile and most commonly used tungsten but you still need a few 1/16" and 1/8"..
you know what I mean???
METAL TYPE = carbon steel
THICKNESS = .250”
WELD TYPE = FILLET
JOINT TYPE = CORNER JOINT
POSITION = 2F
AMPERAGE = MACHINE AMPS SET TO 200 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
ADDITIONAL SETTINGS =  PULSE SETTINGS 1PPS, 40% BACKGROUND, 50% ON TIME
TIPS: KEEP A TIGHT ARC Aim for an arc length that is equal or less than the diameter of your tungsten electrode.
I don't use pulse tig all that much but I do like to experiment so that when I get a job where I feel like pulse would work better, I already know what settings will work because I recorded all my settings
