TIG WELDING CARBON STEEL11GA SQUARE TUBING LAYWIRE
primeweld 225 tig with stuff
The problem with most other really affordable tig welders is usually a really cheap foot pedal and TIG torch.  Primeweld went to extra expense to include a genuine CK17 torch with superflex hose along with a very smooth SSC style foot pedal.
A high quality CK dinse adapter is also included so that you can easily swap out a tig torch or cable when the time comes.
Primeweld also has a responsive primeweld equipment users group on facebook and also has demonstrated great customer support
Watch some more primeweld videos and you will see what I mean.
scroll down for settings
METAL TYPE = CARBON STEEL SQUARE TUBING
THICKNESS = 11GA
WELD TYPE = GROOVE weld
JOINT TYPE = BUTT JOINT
POSITION = 1G
AMPERAGE = MACHINE SET TO 111 AMPS
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = 0.5 SEC
POST FLOW = 8 SEC
TIPS: KEEP A TIGHT ARC
