TIG WELDING .120" wall COPED STEEL TUBE COVER PASS
ceramic 12 stickout
METAL TYPE = 1-1/2” CARBON STEEL TUBE
THICKNESS = .120” WALL TUBE
WELD TYPE = Fillet weld
JOINT TYPE = COPED TUBE JOINT
POSITION = 4F OVERHEAD
AMPERAGE = MACHINE SET TO 150 AMPS CONTROLLED WITH PEDAL AND MAXED OUT ON PEDAL MANUAL PULSE
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
