TIG WELDING HIGH STRENGTH STEEL TO STAINLESS  160AMPS
scroll down for settings used FOR TIG welding high strength steel to stainless steel THICKNESS =  1/2’ TO 1/4"
METAL TYPE = HIGH STRENGTH STEEL TO 304L STAINLESS STEEL
WELD TYPE =  FILLET
JOINT TYPE = TEE
POSITION = 2F
AMPERAGE = MACHINE SET TO 160 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” ER309L
GAS FLOW = 20-25 CFH argon
CUP SIZE =  12
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
