TIG welding outside corner no filler .080" carbon no pulse
METAL TYPE = CARBON STEEL
THICKNESS = .080”
WELD TYPE = FILLET WELD
JOINT TYPE = OUTSIDE CORNER
POSITION = 2F
AMPERAGE = MACHINE SET TO 80 AMPS WITH FOOT PEDAL MAXED
FILLER WIRE = NONE
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
use just enough amperage to flow the puddle.
using a slight back and forward motion can help you determine when you have the right amperage
Once and for all pushing vs pulling mig welding
Video of Dual Shield Flux Core vs 7018 Stick Electrode vertical uphill using an Esab Rebel 285
TIG Welder Settings for Steels and Aluminum with Quick Videos Showing settings and results
var l = window.location.href,
d = document;
