TIG WELDING TITANIUM .040" 1G TEST
scroll down for  settings used
METAL TYPE = TITANIUM 6AL4V
THICKNESS = .040"
WELD TYPE = groove weld
JOINT TYPE = BUTT JOINT
POSITION = 1G FLAT
AMPERAGE = 38-40 amps
FILLER WIRE = .045” CP TITANIUM
GAS FLOW = 20-25 CFH argon
CUP SIZE =  10
ADDITIONAL SETTINGS =PURGE FIXTURE WITH 10 CFH ARGON PURGE
PRE FLOW = .5 SEC
POST FLOW = 15 SEC
TIPS: KEEP A TIGHT ARC
SNIP any end of wire that is discolored before restarting
