MIG WELDING CARBON STEEL 1/4" THICK OUTSIDE CORNER DOWNHILL ROOT UPHILL COVER PASS
scroll down for exact settings used
Sometimes you need 100% penetration and a leak proof weld on an outside corner joint. If the fitup has a 3/32" -1/8" gap the first pass can be welded downhill and the second uphill to ensure full fusion
20 VOLTS 200 IPM .035” ER70S6
THICKNESS = 1/4""
WELD TYPE = FILLET
JOINT TYPE =open butt OUTSIDE CORNER
POSITION = 3F PLATE downhill root
VOLTS = 20 volts
WIRE SPEED = 200 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6 .035"
The technique shown is a very slight side to side motion while keeping the arc on the front edge of the puddle while not far enough to shoot wire thru the gap.
