STICK CARBON STEEL 3/8” TO 3/4" 4F TUBE TO PLATE 5/32" 7018
Scroll down for settings for 5/32" 7018 Overhead
Some Structural jobs are requiring use of 5/32" 7018 rods.
METAL TYPE = CARBON STEEL A36
THICKNESS = 3/8” TO 3/4"
WELD TYPE = TUBE TO PLATE Fillet weld MULTI PASS
JOINT TYPE = TEE
POSITION = 4F OVERHEAD TUBE TO PLATE
AMPS = 175 AMPS
ELECTRODE = 7018 5/32"
ADDITIONAL SETTINGS = ARC FORCE SET TO 10
ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
4f tube to plate 5/32" 7018
