What Color Tungsten for Aluminum? Is it Red, Green, or Blue Tungsten?
tungsten-size-matter-thumb
Great prices on quality tungsten at Weldmonger.com
The best color tungsten for aluminum is not Green anymore.
Back in the day, the main two choices for tig welding were pure tungsten (green tungsten)  for aluminum and 2% thoriated (red tungsten) for steels.
Today there are several better options.
Especially when it comes to tig welding aluminum.
I like 2% lanthanated for TIG welding aluminum as well as an all purpose electrode for all metals....
Carbon Steel, Stainless, Nickel alloys like inconel and hastelloy, Aluminum, Magnesium, and Titanium
When it comes to TIG welding aluminum, the choice of tungsten electrode matters for achieving the best weld quality.
But it really all boils down to what type of work you are doing.
No one type or size of tungsten is best for everything.
The most recommended types of tungsten electrodes for aluminum welding are:
 1. Pure Tungsten (Green)
- Usage: Pure tungsten electrodes are traditionally what was recommended for AC tig welding of aluminum back when transformer design tig welders were the norm. When AC balance settings became mainstream, welders started using other types of electrodes with a tapered tip to make the arc resemble a DC arc.
The instructions on several newer inverter tig welding machines discourage using pure tungsten because arc starts can be erratic with a rounded tip when using an inverter tig welder.
- Advantages: They provide good cleaning action and have a balling effect at the tip, which is was beneficial for tig welding aluminum using a transformer style tig welder.
- Drawbacks: Pure tungsten has a lower current-carrying capacity and tends to wear out faster than other types.
 2. Zirconiated Tungsten (white or brown usually)
- Usage: Zirconiated tungsten electrodes perform similar to pure tungsten except can carry a lot more amperage.
- Drawbacks: zirconiated tungsten balls like pure tungsten. So if you prefer a tapered tungsten for aluminum, there are better choices.
 3. 2% Thoriated Tungsten (Red)
- Usage: While not typically recommended for AC welding, 2% thoriated tungsten can work just fine for AC welding of aluminum. Preparing the tip by either round using DCEP or a high cleaning AC balance setting is the key to making 2% thor work well on AC.
- Advantages: Thoriated tungsten has excellent arc starting and stability and is very durable.
- Drawbacks: It is reported to be slightly radioactive, which raises health concerns, and it’s not ideal for AC welding. ( the final verdict on radioactivity seems to change year to year)
 4. 2% Lanthanated Tungsten (Blue)
- Usage: This is often considered the best all-around tungsten for both AC and DC welding of various materials, including aluminum.
- Advantages: Lanthanated tungsten electrodes provide excellent arc starting and stability, and they perform well at both low and high current settings. They are also durable and have a long lifespan. A tapered tip can be used for crisper arc starts at low amperage and for pinpointing the arc on fillet welds.
- Drawbacks: Lanthanated tungsten needs re sharpening slightly more often than 2% thor, or 2% ceriated.
 5. Rare Earth Tungsten (Purple, E3)
- Usage: Purple tungsten electrodes are becoming increasingly popular for AC welding of aluminum due to their versatility.
- Advantages: These electrodes offer excellent arc stability, easy arc starting, and long electrode life. They work well with both AC and DC currents and have a low burn-off rate.
- Drawbacks: While more expensive than pure tungsten, the benefits in performance and lifespan often justify the cost.
 6. LaYZr tungsten electrodes from CK worldwide
Usage: good for medium amperage range welding for both aluminum and steels.
good low amp starts and good restarts.
to me LayZr tungsten performs almost the same as E3 purple tungsten.
For TIG welding aluminum, 2% lanthanated (blue) and rare earth (purple) tungsten electrodes are generally the best choices. They offer superior arc stability, longer life, and versatility for both AC and DC welding. While pure tungsten is traditional and still widely used, especially for AC welding, the newer formulations of lanthanated and rare earth tungstens provide enhanced performance and are preferred by many welders.
